two different "models" of Perfects 12.1 hits wrong!
31337hxr
Okay guys, I ordered TWO infinity kappa perfect 12.1 from onlinecarstereo at exactly the same time and the exactly the same order.
They came in exactly the same boxes but one of the design had a "plexy-glass" o-ring while the other has a "rubber' surround o-ring.
a picture can be seen here:
the left sub is rubber, the right sub is plexy glass. i just didn't take out the liner yet. But i did take it out now and it solved nothing.
The problem now is I noticed that the "plexy-glass" o-ring infinity perfect continues to hit small signals after it hits a large beat while the one with the "rubber" o-ring hits the large beat, and then recovers and shows no signs of after hitting......
i can't explain but here's what i mean:
Assume that XXX = large beat x = small beat
music current flowing - >>>>
Rubber surround subwoofer: XXX XXX XXX
Plexy-glass subwoofer: XXX x x x XXX xxx XXXX
as you can see, the plexy glass subwoofer continues to hit little tiny signals while the rubber recovers and stops and waits for the next beat.
Anyone care to explain why?
This is going to probably be wrong but maybe one of 'em is the 4 ohm series and the other one is the 8 ohm?!?! I am takign a stab in the dark //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
31337hxr
31337hxr
Los Angeles
Si-R
    May 31, 2024
    May 24, 2024
