Two 15's IB or Two 12's ported in 5 cubes?
adulbrich
Olive oil un-virginer
14,433
123
Ames, Iowa
I just bought a pair of Fi BTL N3 15's. I am re-coning them, because they are d2's and my amp is only 1 ohm stable. I'm not going to run a Brazilian at .5 ohms daily..
I have 5 cubes net of internal box volume if I go ported. This is wayyy too small for a pair of 15's. I was thinking about doing an infinite baffle build again.
The 15's would have more cone area. How much more? I don't know. I haven't done the math yet and I have to got to work at 4:15.
Between the two options, which would be louder? IB with the 15's would have a flatter response down low, but what music plays under 20hz? Does decaf even?
It would be cheaper to do the 15's, because I just have to build a baffle, not a custom fiberglassed box. Also, there are some cones on here used.
Thanks for your help! I will add pics of my N3's later if anyone wants to see them
The n3 is a 7 spider stiff spl monster and i wouldnt think it would be worth a fvck as a ib..i would get some custom recones made with some softer than stocm soft parts for daily
I was going to build them custom
if you have 5 cubes to work with recone them to 12"s
That was the original plan, but I wanted to know what everybody thought. IB would be a lot cheaper and easier. I just want it to be as loud as possible while still sounding good
Pics:
My cat had to check them out too, haha
I think its been said already, but its built to be an spl burp sub, although I have seen people use them in walls and they sound good. You can try and tackle an IB with these, if it doesn't work well you will still have the drivers to recone to whatever you please for a ported enclosure
Why would it not work for IB? The motor is plenty deep for excursion and it has lots of motor force. No matter what, I am re-coning the drivers before I use them. They are the wrong coil configuration to use daily with my amp. I will put a custom spider pack on them.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
adulbrich
adulbrich
Ames, Iowa
adulbrich
audiobaun
    May 19, 2024
    May 19, 2024
