Tweeter Spheres - pics and examples
This is the basic design, I can adjust it for any size tweeter and have it printed out or possible milled out in a cnc depending on cost.
Any recommended change or something I should consider ?
Depends on the tweeter. If it has a lip, you want a matching lip. Each tweeter mounts differently. Looks good. It would be nice to see a bit more surface area around the tweeter. I have some paper mâché eggs that I will experiment with also.
aiming at the rear C-pillar (opposite side) for each tends to work out well - result is a wider sound stage than aiming at head rests.
you'll need to attenuate the nearest tweeter if they are more on-axis.
imagine a laser beam coming out of the center of a tweeter (or speaker). that is the axis. you are on the axis (tweeter pointed at you) it is on-axis. if you are not (tweeter pointed away from you) you are said to be off-axis. being off-axis should be further clarified with an angle (in degrees) with 90 degrees being perpendicular. this factors into the polar response of the speaker/tweeter at each frequency. polar plots are useful in determining what you will hear as you move from being in front of a speaker/tweeter to what you hear when it is pointed away from you.
attenuate is just a fancy word for "turn it down". decrease level/volume of the nearest tweeter and the sound stage will become more centered (since we localize sounds above 3kHz based on intensity (volume) and not on pathlength).
thanks for asking for clarification. i'm sure it will help other as well.
@keep_hope_alive; is the goal to have the paths cross at a certain point in the vehicle? Part of the reason I ask is that 2 of the vehicles I am thinking of doing this on are pickups, so no c pillar to aim at. I know I can just guesstimate, and am probably over thinking it.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
tat2bass
