tutorial for installin a set of AMPED components?
Here you go -
1. Connect woofer to crossover.
2. Connect tweeter to crossover.
3. Connect crossover to amp.
But seriously, what do you need to know?
Here you go -
so just hook up the amp's rca's to the mid/high on the HU output?
what about impedances?
last i checked most HUs dont have a mid/high RCA out, maybe front and rear? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
But yea, its very easy, just hook the amp up, then hook up the comp set. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i need a tutorial for installing a set of components that is amped.
i have searched on google too and cant find one.
It's self explanatory! You don't even have to worry about impedance!
(Most 4-ohm stable amps are 3-ohm stable.)
yeah but how are they with the amp?
same as with a sub?
in which case they are weird right?
cause the woofers are 3 ohms.
Then make sure you have an amp that's at least 2 ohm stable. @ 3 ohms, you need an amp that can do about 150-250RMS @ 2-ohm (That is if the speakers need 100wrms)
speakers need 65 wrms.
so i need one that can do like 100-150 at 2 ohm?
do that. the focals are rated at 60rms but can most likely take more. set your gains accordingly on the amp. they will give the amp a 4ohm load on each channel.
Sanchito
O.G. status
Sanchito
Houston
Sanchito
