Trunk Setup Opinion?
Which budget setup are you feelin?
  • Total voters
    31
You cant' really fit a horn into a trunk, or even a car for that matter. All you could build would be a quarter wave resonator with a tapered mouth, why car audio guys call that a "horn" idk. Anyway I'd just do a ported 15 facing the trunk lid. KISS (keep it simple stupid) Unless your box builder knows how to use akabac or hornresp, he has NO idea how a enclosure with changing cross sectional area will model. Even if he does, modeling it in a car is tricker still.
Kool ****! thanks for the input! So sub up port back? both up?
well he's not into audio or competing but I know he'll want to crank it up no matter what's going in there. And who knows, having a little junk in the trunk might turn him onto the CA scene. But yea, not picky bout dBs, just want to get the maximum output out of whichever sub I go w/. Anything will be a huge upgrade
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
718
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
O.G. D-Wet
[]D [] []v[] []D
O.G. D-Wet
Maple Shade, NJ
O.G. D-Wet
    May 12, 2024
Brendon Jenness
    May 11, 2024
