trunk rattling
  • 4
carguy
canada
OK i got a 92 saturn sl1 sedan, and every time i play my sub woofer ( 500watt jenson amp) (l000w blue wave sub) I just have ratteling. Now i've put insolation underneath the spare tire and it took away some ratteling, but there is still some left... any other things i should try?
thx
try putting the sound deadening substance along the sides of your trunk and on the top...also you should see if you can make your truck any tighter of a close....like where the latch is see if you can move the latch so that it closes a little tighter...that hsould help a little...good luck
k cool i will try it. I also have another question. everytime when im playin some good bass songs farely high, the light on my amp flickers. Does this mean not enough power going to it? ****** to much juice?
possibly...you also might try runing some bigger wire to the amp....how many watts does your amp put out rms right now and what size wire are you running to it??? that'll help us out a bit more....good luck
Alright I got all the wirng from an import shop, the guy said it was good enough for a 500watt amp and stuff so i baught it. But i'll try 4 gauge
you also might see about turning your gain down a little also what kind of car do you drive....the problem also might be that your alt. is not providing enough power for your system...good luck
I drive a 92 saturn sl1 sedan... It's not actually mine its my brothers car. Hes just got alot of ratteling and hes away for a week down in detroit so im trying to fix his problem.
i would advise going to 4 gauge....just as a precaution....i believe 8 gauge is only recomended for systems up to 150-200w.....good luck
You seem to be a pretty nice dude.
To OP: Try doing the Big 3 in 1/0, it may save you some money from upgrading your charging system.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
791
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
4
carguy
carguy
canada
Synyster97XLT
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
