Trunk opening just a little too tight..
-BenBen-
Team L.oud A.s F.u**
SO I have a pontiac G6, and also 2 xfl 12s. box needed is 4.5 cu, and my trunk opening is 2-3 inches too thin to get the box in. what options do i have left? I wanted to run subs forward, aero port in trunk on driver side.. so can i do a 2 part box and assemble in trunk and if so how is it done? i also have been told do subs up, port side, but was told i would have a really inefficent box if i did it that way. last option may be build in trunk? but then i cant take the dang thing back out. any help is greatly appreciated
we dont have much trunk space in our g6's lol thats why i picked dc subs cause they like smaller ported boxes. maybe change the orientation of those subs with how they are facing if your dead set on running those. subs up port side or back ?
Generically sub up, port back, build it in the trunk.
Some people are apparently getting loud now sub and port forward without sealing from the trunk though, might have best results that way.
Or, try to put it in through the back seat, pain in the *** most of the time though.
we cant put in through back seat the rear deck has a low spot like 13inches . would have to have a super short both height wise . i pmed him my measurements off my box awhole back but mine is only 3cuft net
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
749
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
-BenBen-
-BenBen-
Down South
mklett33
    May 20, 2024
    May 20, 2024
