Tri-way should i or not
95RAM
I am going to buy a kenwood h/u with 2 preamps (front and rear). I will also put a us acoustics 65 watt by 4 channel amplifier that will power four 6 and 1 half inch speakers, also putting on a triway to the rear speakers to power an 8 inch sub. I would like to know if that is a good way to do it?
would it really matter how many ohms the 3rd speaker was as long as you wired it to so it is a 4 ohm load
It HAS to be 8 ohms (DVC 4 or SVC 8 works) unless you have a bad *** amp. If it's less than 8 the amp will see less than 2 ohms stereo.
Just look at the sub - (Assuming it's 8 ohms) if it's running in tri mode you're just running the sub from the bridged channels - since each channel effectively sees half the load that's the same thing as running in 4 ohms stereo. When you add to that the other two speakers already running in 4 ohms stereo - the result is your amp is seeing 2 ohms stereo.
If you drop that sub to 4 ohms that means your amp is already running at 2 ohms stereo and when you factor in the other 2 speakers you get a 1.33 ohm load on each channel.
Hold on man. You can run 4 speakers (2 on each side in parallel) from channels 1 & 2 of the amp, then bridge the other 2 channels to the sub. You just wont get fading between the 2 sets of 6.5's. You don't want to run 4 channels to separate speakers and then also use 2 of them for a sub. You won't be able to lowpass the sub, or adjust sub power independantly of the speakers. Bad idea.
Hey Wonderbread my manual that came with my usx-4065 recommends just that for triway config. They recommend a 15.9mH lowpass filter inductor for the sub and high pass passive crossover network for your satilite speakers. Now I'm no expert but the manual says. Also 8Ohm sub is required. Thanks CC
95RAM
95RAM
Jensen Beach, Fl
Wonderbread
