too much port area? need help
skippy90210
so i built an enclosure for 4 alpine type s 12s. it has an 8 inch diameter aero port im thinking it might be too big because it does not hit low notes as well as i wanted. the port is 19 inches long and the box after displacements is a little under 5 cubes i have them wired to 2 ohm 2000w so 500w each just as rated. could my large port be the problem with my subs not hitting the lows good? my box dimensions are 33 wide 21 tall 14 top depth and 22 bottom depth, i put it in a sub box calculator and it says its tuned to 33hz
so i built an enclosure for 4 alpine type s 12s. it has an 8 inch diameter aero port im thinking it might be too big because it does aero low notes as well as i wanted. the port is 19 inches long and the box after displacements is a little under 5 cubes i have them wired to 2 ohm 2000w so 500w each just as rated. could my large port be the problem with my subs not hitting the lows good? my box dimensions are 33 wide 21 tall 14 top depth and 22 bottom depth, i put it in a sub box calculator and it says its tuned to 33hz
5.86 gross cubes. Roughly 4.6 after disp. Box is way too small for 4 12's, that's why you're not hitting lows. You're also at nearly 11" port per cube. With an aero that's too much for those S' s.
so its a design flaw on my end what should i do to fix it? the manual says 1 to 1.5 cubes per sub ported so i thought that was enough air space, just a smaller port?
The port isn't too big, the box is too small. The whole ratio of port area to box volume rather assumes that you have correct/adequate box volume for your subs.
I would suspect that if there's no other problems with the box it would perform better with a single 15 or pair of 12's.
nope their manuals specs ****. You'd want at least 1.5 or more for a 12.
here are some temporary solutions for you
-Unwire two of those subs and only run the other two
-Invert the subs so the motor is on the outside and switch over to three 4" round ports around 13 inches long each. If you can have the ports stick out externally
skippy90210
skippy90210
ramey, PA
skippy90210
vegang
vegang
