Too big of an enclosure?
ace_800
Ok so I'm currently running a 03 12" quad 1.4 RE XXX in an enclosure thats about 4.98^34htz that was designed by someone here. Its great for daily, just don't put up numbers that I should be I believe. I've got it on an Exile 2400.1 thats 2400+@1, 1600@2 depending on whatever the rise is.
However I've seen that RE recommended that it be in a box thats 1.7@32 or 2.2@34 and I've been told to tune higher, around 48-50htz. So what should I realistically be built to?
I'm no expert, but I believe RE specs are very small for what actually works well in a vehicle. That being said, your box does seem pretty big for a single 12
Ask the guys you talk crap about that are local to you?Why would you tune it to 48-50hz?
What you talkin, local to me? The douche that believes you can wire 2 D2's to 1 ohm? LOL
Just what I heard to put up numbers, one guy in a Scion XB with 2 SA12's off a RF that does 750 put up 142 and was tuned to 48 I believe.
Are you going for just numbers? If so I would try out a different 12 in around 2-2.25ft3 tuned to work with the car's peak.
If you are just wanting "loud" while musical then I would adjust the volume down to around 2ft3 with a generous amount of port area and tuning based on the music you listen to and how it will load in the application.
Well based off the Custom type X I was running a few months ago my cars peak is 34. I was going for SQL and was told this box was designed to do so. I just figured I would put up better numbers as well. Though looking at the recommended volume, I'm not so sure now.
I wouldn't mind having a 2nd box that could put up better numbers with this sub or one that can do better numbers and sound well doing so. I know it can take power, just looking for the right volume/tuning to do so.
Why are you trying to use a XXX to hit numbers? I would do a box around 2.5 tuned to 28-32 if that were my sub. But the RE XXX isn't the greatest woofer to meter.
Just what sub I'm running atm. I understand its not the greatest, but seeing as it can take a good amount of power I should be over 135 fairly easily with the amount of power I'm sending it.
Here is the design
Yeah I know what you meant… the censored word in my last comment was s u x. It wasn’t anything towards you it was the situation lol. I really...
17
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
ace_800
ace_800
Okinawa, Japan
bhsdriller
    May 12, 2024
Brendon Jenness
    May 11, 2024
