to FUSE or not to FUSE?
im sure of it, as long as i make sure my gas lines stay on the fuel injectors i shouldnt have that problem. havnt for this entire past year.
Can you tell the future? Can you predict the outcome of an accident? Do you know what will happen if a non-fused 1/0 +12v wire grounds out in the event of an accident?
What do you guys think of fusing with multiple smaller fuses in parallel/stacked vs. one big fuse? Suppose to be less resistance with multiple smaller ones but I don't know if there would be any noticeable difference.
so what type of amp do you suggest for my 1600+AMPS of current being pulled by my sd16k
unless you have some insane alternator/battery setup up front theres no way your ever gonna pull 1600 amps of current from the front end of your car because it most likely cannot produce it. your leads running from the front are only going to charge the large battery bank you are going to need in the back of your van to support that huge amp. you only need to fuse your power wires for the maximum amount of current they can safely carry. i'd say 250 to 300 amps of fusing per run of 1/0 would be good. i wouldnt think with a good battery bank you would see a huge difference in your score from running fuses or not.
The only way 16k watts would draw 1600 amps (especially with how efficient they area) would be if you were running it at like 10V, in which case you should probably just give up on the hobby //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The fact that you post scores and claim to compete, and then ask a question as blatantly stupid as this one just baffles me. You want an answer and supporting evidence though, so here it goes.
You have the option of whether or not to fuse the Big3 upgrade because the factory didn't anyways. But not fusing a large gauge wire tapped directly into the positive lead that runs the entire length of the car is just stupid. With that long of a wire and it being so close to many grounds, it only takes 1 breach in the insulator to ground out. And depending on where it shorts, and how strong the connection is, you're going to have problems.
Most people don't understand how an electrical fire starts, so let me break it down for you. Think of it this way... any electrical device has some sort of resistance to it, and when a voltage is applied, electricity flows. To increase the flow of electricity, you either need to lower the resistance or increase the voltage. Wires are rated in amps, NOT volts. You can be pushing only a couple of volts through something, but if the load on the circuit is low resistance, you'll be drawing quite a large amount of amperage.
Now, imagine the wire is pinched, it goes through the insulator and grounds out. Now there is a 12V+ power source touched a GIGANTIC ground (your entire car) and it goes right back to the battery. Basically, the circuit has almost NO resistance and a 12V source being applied. That wire is now going to carrying an ASSLOAD of current. Far greater than it could possibly ever hope to manage.
But it's all good bro, shit happens, that's what the fuse is for. Fuse pops and the circuit is interrupted.
OH SHIT! YOU DIDN'T FUSE DID YOU?
Bummer, the wire is going to heat up so hot that it physically melts and catches the insulator on fire. And who would have guessed that was right underneath your car's carpet.
I think you get the idea, FUSE it or leave the forums //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i have 2 runs of 4/0 directly from the alt, that go under the van next to the frame, back to my main battery set up.
but from the back batteries to my amps there are none and there will never be any because you loose current draw through a fuse and if you pop one in the lanes your done.
and i seriously doubt that serious competitors use em from the back batteries to the amp.
thanks for the advise, and nice kicker in your avatar, is that a comp series:laugh:
Why yes, it is a Kicker comp. Good job... brand recognition. By the way, I'm getting the slightest inclination that you meant that as an insult. No need to worry though. There's not a chance in hell it will be taken that way.
Any day of the ****ing week, I'd rather have mediocre gear and good understanding of WHAT IN THE HELL IM DOING than to flaunt how much expensive products I "plan" to buy and have not a god **** clue what I'm talking about.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif That avatar is from when I first joined the site. Current equipment is a Soundstream 2.2k and a KO12A Konaki which will be installed during Christmas break.
ok, i"ll give up on my hobby, maybe i should be weak like you and run a couple of 10s:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
stevew007
