Great -.-Probably using the antenna or RCA as the ground...
Well it shouldn't be coming on when the ground wire is disconnected and might be the reason you are introducing noise into the system. Check your wiring to make sure it's not grounding out anywhere... you can do this with the multimeter (upload a pic of the front of the multimeter and we might be able to help on how to do it).Great -.-
Could that particularly harm the 2-channel amplifier.
Im hoping that wiring the ground directly to the battery will help. Wired it to the distribution block, still getting noise but now the volume is of the music is extremely low even when high on the HU and theres no bass response...
Should I check this by mainly taking the neg ends of the dmm and putting it on the RCA and a power source and same with the antennae or I can narrow it down by unplugging both sources and the HU ground wire and seeing the response.Well it shouldn't be coming on when the ground wire is disconnected and might be the reason you are introducing noise into the system. Check your wiring to make sure it's not grounding out anywhere... you can do this with the multimeter (upload a pic of the front of the multimeter and we might be able to help on how to do it).
Also remember all the settings are lost when the car/deck loses power....
Hold off on any filter or noise reducer. If it's all properly installed there is no reason it'll have noise. Rather than bandaid it fix it...Today I will try the ground to battery and the ground loop isolator option.
Aswell as contacting Phoenix Gold for replacement woofer options.
Already followed that procedured, no luck.Hold off on any filter or noise reducer. If it's all properly installed there is no reason it'll have noise. Rather than bandaid it fix it...
That procedure on the link I posted should help you get up and running...
Try swaping the rca isolators and see if one is bad...run wires for the H/u power and ground straight to the battery...check what your getting for volatge with a dmm before connecting. problamatic installs can be a real ******* inducer. keep at it...Well, the ground loop isolator worked in eliminating the alternator whine but unfortunately there would be no sound coming out of the left channel with the ground loop isolator's RCA. But with the KnuKonceptz RCA cable, you can hear the vocals and other musical elements through the door speakers.
So I decided the issue may be that there was only one component set plugged into the amplifier and it was plugged on the right output, so I took the pioneer 6x8 and hooked it up to the amplifier aswell so that perhaps I would be able to hear the left side through it. No luck, instead it played the right signal through both speakers, so i hooked the KnuKonceptz RCA back and up and it played normal with the exception of the squealing.
Another new issue that may be connected or not with the alternator whine grounding issue is that the HU randomly turns off and back on when the subwoofers hit hard or the even just at random moments such as when the subwoofers aren't plugged in and it may restart in a series. I slapped the wires around a bit behind the HU to see if it was just a loose wire but the slapping had no effect. It was as if the HU was just randomly turning off for no reason.
I also turned the HU and did an elimination process to see if the HU was grounding out somewhere else besides the designated ground wire. So I first disconnected the ground with the amplifier on....no response....then the RCA cables....HU is still on....then the antennae...HU cuts off, so I plug the RCA cables in....still off....then I reconnect the ground...HU turns on.
I swear the problems get more and more weird with every day.
Actually my amplifier remote wire is connected to the red wire of the HU and the red wire coming from the wiring harness because the HU didn't specifically tell which wire was the remote wire and I tried every available wire(P.CONT, EXT. CONT) to see if it worked as a remote wire and it didn't. so I used the red wire. The on/off issue has seemed to gone away for some odd reason. I unplugged the antennae and hooked the HU up and the whine is still present. The remote wire coming from the HU is going to the mono amplifier and then another remote wire is coming from the remote port in the mono amplifier to the 2-channel amplifier.Somehow your head unit is grounding out through your antennae wire. I think that's what's causing your wine. Also, make sure your amp remote wire is hooked to your remote out. If your remote wire is connected to the wrong wire, that can cause whine also.
Also, if you unplug the amp (disconnect it), does your headunit still turn off and on? If not then I think you might have a power (lack of it) issue. Have you done a big 2 upgrade?
