Today was the component system install day for my truck and everything was ready to go.
I was going to hook up my Phoenix Gold Rsd 6.5" component set to my Profile AP1000 2-Channel amplifier. So immediately I removed the door panel of my truck and any/all other parts that needed to be taken off for the wiring. Luckily, Ford conveniently uses high quality plastic clips and pieces which can stand large amounts of abuse to hold their panels in(sarcasm). But it wasn't the first time I have taken the door panels and other parts off and it sure wouldn't be the last.
After the door panels were removed and set aside, we began to cut the wholes into the panel where the tweeters would comfortably sit out of the range of the window roller and where they would not hinder the insertion of the door panel after the components were installed. So after the tweeters were placed in the door panel, and the mdf baffles were bolted into the door to hold the midbass....and the crossover was also mounted in the door panel; it was time to do the wiring to the devices.
Immediately I ran the wire from the amplifier to the crossover and so forth from there running from under the step cover. Everything was wired up and unfortunately unknown to my knowledge, I had wired the polarity wrong due the diagram on the amplifier which confused me. So when I turned the radio on, I was greeted with a nice popping noise from the midbass, a nice little clicking noise from the tweeter and a wonderful burnt smell emitting from the door panel. Immediately I knew what was wrong and quickly re-wired, but the damage had already been done though the tweeter began to work properly(to an extent), the midbass voice coil had been fried. So I replaced the burnt woofer with the woofer from the other side, it all sounded fine now with some adjustment with the gain and crossover from the amplifier.
Unfortunately my dilemma consisted in replacing the midbass and that would solve the problem right? Unfortunately more problems appeared, besides the difficulties in placing some of the plastic panel pieces back into the truck, when I tried to put the other door panel on, I discovered that my measurements were off and that the screw holding the spring in the tweeter conflicted with the metal frame of the door panel which rendered the door panel unable to go on the frame. Great....
Dilemma number 2, which would honestly just call for a shorter screw and hopefully, though not positive, that might solve that dilemma, so I turn the HU on once again. But instead of the nice actual sound that came from the tweeter and midbass last night, I was greeted by a high-pitch squeal.
Between the difficulty of getting some of the pieces back on the vehicle, the continous tweeter and midbass problems, and the problem concerning the tweeter placement on the other door panel. I am this close to taking a sledge hammer to the vehicle and system entirely, and sad thing is....the actual change in performance from wrecking the whole ordeal would not differ from the current performance Im getting out of it now.
Any tips, ffs just someone help me. -.-
