tips for building a box
yea screws arent NECESSARY, but it does make the process go faster. By using screws you dont have to wait for the glue to dry. I made a box today and i had the subs bumping before the glue was even dry all the way. So in that case, screws are good.
Remind me to never buy boxes from you.
I quit using screws. I am now using 2" 18 ga. brads and a gun. I also started using Elmers probond. That is some good stuff right there. Of course I use this stuff for daily driver boxes not comp. boxes.
i wouldnt build a box without screws unless its either not going to be extremely loud or the subs are light! why cause they will fall apart i tought wood glue is all that was needed till last night
I JUST finished a box for 2 DD 9515's, 2- 6" aeroports and with 1/2 power hit 146.3 on its first burp. NOT A SCREW IN IT! The subs are 50lbs each.. box construction>screws.
The wood glue makes the bond, not the screws. IF you use screws, pre-measure to make sure the screw is dead center in the middle of the MDF, pre-drill(not an option), do not overtighten(wood split=weakening), and still let the glue dry before moving on.
These are only suggestions from experience. You can build a box however you want.
I JUST finished a box for 2 DD 9515's, 2- 6" aeroports and with 1/2 power hit 146.3 on its first burp. NOT A SCREW IN IT! The subs are 50lbs each.. box construction>screws. The wood glue makes the bond, not the screws. IF you use screws, pre-measure to make sure the screw is dead center in the middle of the MDF, pre-drill(not an option), do not overtighten(wood split=weakening), and still let the glue dry before moving on.
Did you use clamps or brad nails?
my subs point forward and i got 3 subs. so it strains on the box alot more then say a box with the subs on top. maybe it was just bad luck or something last box i had that didnt happen to it. or any other box ive had. i did use some wood glue called loctite from walmart. i tought that was enough. but im switching back to gorrila glue lol
also my box is close to 7 cubes and the baffle is 15x35 inches. probably flexing to much and with the weight presto one broken box. second layer of mdf on it should fix it permantly, i fixed it and hasnt broken any more but i dont trust it
cazorp
cazorp
Shreveport,LA
nVRuckus
