Time to run active!
na_rsx
Incriminator Audio FTW
Been doing a lot of research, and been looking for a decent mid and tweet that wont break the bank, i was going with the AA Carbon Mids, but the price is a little high. My doors are completely deaden, and plan on sealing all the holes, mlstrass is going to help me mount these and set it up properly. I was thinking about this combo:
Mid:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-374
Tweeter:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-804
I want decent bass with clear high, nothing over the top or l337 lol.
I don't have any experience with those particular tweeters, but I would spend a little more on a decent large-format tweeter (if you have the room).
It'll give you a lot more flexibility with your crossover point and they typically are able to handle more power in a more controlled, less "harsh" manner.
I was planning on getting a Nine.4, and thats 65x4 @ 4ohms, ill just adjust the gain moderately. But right now i am on PE looking at other tweeters, space is limited, but have some wiggle room! I want to place the tweeter in the hole i already made when i had my DLS comps. Btw here is my door:
Also the other amp i might use is the mb quart dsc4125, i can run the mids and tweets at 8 ohms with still plenty of headroom. Need some answers soon, gonna be making my purchase soon!
As little as possible, but i already decided, getting the Dayton RS 7" mid in 8 ohm, and the Morel MDT12 in 8 ohm as well. The mid is 60rms, and the tweeter is 80rms, and the Discus amp is 125x4 @ 4 ohms, so at 8 ohms i should see enough power to make these babies shine.
Also my headunit is a real powerhouse as well, one of JVC finest headunits ever made. Might connect my stock sub just for a little extra umph.
Total for the mid and tweet shipped is $121 from PE, so yup //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
okay a little revisions i made, the mid i chose is not good on the high end, and the tweeter is not too high as well. so how bout this?
Vifa PL18WO09-04 7" Woofer 4 Ohm
Parts-Express.com:Vifa PL18WO09-04 7" Woofer 4 Ohm | Peerless Vifa PL18WO09-04 bass mid midbass mtm poly cone 2-way Tymphany vline logic tymphany09
*Power handling: 100 watts RMS/300 watts max *VCdia: 1-1/2" *Le: 0.56 mH *Impedance: 4 ohms *Re: 3 ohms *Frequency response: 37-4,000 Hz *Fs: 37 Hz *SPL: 89 dB 2.83V/1m *Vas: 0.88 cu. ft. *Qms: 2.53 *Qes: 0.33 *Qts: 0.29 *Xmax: 6 mm *Dimensions: A: 7-1/8", B: 5-3/4", C: 3-1/4".
Vifa D20TD-58-06 3/4" Dome Tweeter 6 Ohm
Parts-Express.com:Vifa D20TD-58-06 3/4" Dome Tweeter 6 Ohm | vifa D20TD-58-06 3/4" Tweeter 6 Ohm tweeter dali vifa vline peerless tymphany waveguide hf high frequency mtm Symphony of Savings npa00453 tymphany09
*Power handling: 100 watts RMS/200 watts max *VCdia: 3/4" *Impedance: 6 ohms *Re: 4.2 ohms *Frequency response: 2,000-30,000 Hz *Fs: 1,700 Hz *SPL: 87.5 dB 1W/1m *Dimensions: A: 3-11/16", B: 2-1/2" plus notches for terminals, C: 3/4".
so how do they sound?
i like the vifa combo better, and ill fit that ****en tweeter if i have too lol
They get delivered later today or tomorrow, dont have them yet.
I like those Vifa's at PE as well, those are identical to the 6.5's Soundstream used to use in their $500 Exact comps in the late 90's (except SS made Vifa paint the frames blue).
From what I understand those were very highly rated in the late 90's.
na_rsx
na_rsx
With Jessica Biel
James Bang
michigan born
    May 14, 2026
michigan born
    May 14, 2026
