Thors 09 Build Log
Ended yesterday with 149ish with a make shift seal job and without the box sealed.
I'm pretty much beat! It's been pissing rain non stop so work has been slowed. I did get the box sealed, rewired everything and made a make shift stand to hold both 5k's. As soon as I get some more wood I'm gonna move the silver amp to the left side and have both 5k's standing one in front of the other.
I used the original back and marked where the screws were on it so I wouldnt tap into a stripped hole. Drilled all new holes and sunk 3 screws into the 45. Tomorrow I'll crawl in the box and resin along all cracks just to make sure its sealed.
You can see the marks I made.
All tests yesterday were with the amp settings and HU settings the same. I know that the amp will react different with a difference in impedance rise caused by a diff. box and tuning. Hopefully tomorrow I'll be able to do some amp tweaking and gain some more output.
Had a scrap piece of wood so I did a mock up of what I was considering for sealing the cabin.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Behind the sides will be stuffed with foam. I made the trim piece that goes along the top of box face that will allow me to put foam around all edges.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Got lots to do before leaving for Pittburgh Sunday.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Got it pretty well sealed up with Ducttape. Tomorrow I'll throw it on the meter and maybe take a vid or 2.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sealing the cabin made a huge difference! Even if it is only tape holding the boards in place.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
If it pans out I'll make some fiberglass panels helping to seal and smooth at the same time.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
haha 200mph tape? You should be golden
i know you've mentioned it before, but...
would love to see the faces on some these guys with bigger subs when you are just as loud if not louder. //content.invisioncic.com/y282845/emoticons/awesome.gif.4430a219d9aaaa6cadc75e9290979dfb.gif
Thanks for all the positive feedback fellas!
First round of tests are in the books and I'm not too dissappointed.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I have a few more tests to run and placements to try then I'll rip it up and push it as far back as possible and still fit 1 Atomic behind it. We shall see whats loudest with this box and finish it up there.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Lil vid for ya:p:
thorshammer1
thorshammer1
Auburn, NY
uGotF-ckedUp
