This setup a good idea?
Beatkeeper1
2000 Nissan sentra
stock alt
diehard platinum battery
Big 3
Single run 0 gauge to the trunk
2 Kinetik hc800 cells
Stinger 30 farad cap
for an...
audioque 3500d
2 10" fi BL
2000 watts rms.
If anyone has any suggestions or cheaper options that will do the job just as well please let me know
yea it should be a good setup, caps are basically just audiobling (that make our system look like a bomb...) but they are pretty useless, and i agree, save your money and get another small battery. but yes 1 run of 1/0 AWG should be good enough for now, run the 1/0 AWG from front battery, to the back batteries, then if you need to add another run of say... 4AWG for your 4 channel, you can just run it from your rear batteries.
what type of isolaters do you guys reccomend? Also what's the best way to keep batteries locked down in your trunk? I was thinking about some of those ratcheting ccargo straps.
The cap works and will help. People say they dont work and are not worth it but they are wrong I use to have dimming lights and got a cap and it was gone after that. My friend also used on with his 2 hifonic amps. THEY DO WORK
have you don the BIG 3????
do the big 3 and remove the cap and see what happens.
-=Jason=-
//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
I have a few more good questions that i've tried searching.
1. how do you guys crimp your 0 gauge ring terminals- a vice?
2. I also want to run a voltage gauge pod for voltage. Where will be the most accurate place to take a reading from?
3. How do you guys stop your batteries from sliding around the trunk?
Beatkeeper1
Beatkeeper1
Cranston RI
Beatkeeper1
