This design look right?
Lil_KB
I had psturmer draw me up a design, for 2 12" Type Rs. it'll be double chambered, each sub with 2 cubes and 40 square inches of port area, both ports will be side by side in the middle.
each sub's chamber will look like this, everything will be upfiring.
So, any criticism? will i have port turbulence or anything with the angled corners?
We can't really tell you anything without the dimensions, and if you gave us those, then it wouldn't really be fair to the designer. If you're worried about the design, don't you think you should tell the designer that?
I always suggest to ppl to add the 45degree angled pieces to the out side corners of the ports, not the inside, as the air moves inside the port it will travel a lot faster around the out side corner than it will on the inside corner. Taking a router and round over bit to the inside corner is all that need to be done.
Lil_KB
Lil_KB
Louisiana
PV Audio
