This be a good amp/sub match ??
I thought i mentioned it but i actually have 2 of those subs.....
I would look for an amp closer to the subs RMS or the otherway around. The RMS is what you need to base your sub to amp compatabilities on. the amp runs 600 WRMS and the sub is only rated for 300 WRMS.
that set up will be fine. the amp does 600 ish @ 2ohms as long as the two subs you are using are 4ohm then eveything should be ok
Yeah that should work that way but if it is doing 1200 at 2 ohms and both subs are 4 ohm then the subs will fry after a while. After doing research I say you will be fine.
dej
dej
nj
Jason Sybert
