Thinking about re-foaming my old school JL w6v1... is it worth it?
joelx21
Several days ago, I got a brand new Alpine type 3 1043D sub in my 2000 Z28 Camaro. I thought that it would blow my VERY old 10 inch JLW6V1 out of the water, but it just doesn't sound as good.
I'm not sure if it was installed incorrectly, but the W6 seemed to fill my car with base unlike the Alpine. In order to get it to hit about the same as the W6, I needed to set the "sub woofer"seeting to max, had to turn on the "Bass Boost" on my ipod, and turn the bass all the way up on my bass nob... and sadly, it still doesn't hit quite the same. The guy that installed it told me that it's a different kind of sub and that while it may not fill the car with bass as my old sub, the bass that it produces is cleaner.
With all this power going into the sub, my lights flicker... something that never happened with my W6, even when I turned it all the way up. So now I have to invest more time and money doing the BIG three, might need to get a cap, or even get a better alternator... I already have an orbital battery. The guy also told me that the JL was more efficient, thus it needed less power compared to the Alpine. This I get, but I still don't feel that it explains the big difference in bass. Needless to say, I'm definitely missing my old sub. I've even thought about getting it re-foamed.
I would hate to return the Alpine, but luckily, it's an option.
What do you guys say? Would it be a step backwards re-foaming the W6 and putting it back in my car?
Here are the specs on both:
JL W6V1 10 inch
http://mediacdn.jlaudio.com/media/mfg/9013/media_document/live_1/8_12W6_BDS.pdf?1317790304
Alpine Type R 1043D
•Sensitivity: 83 dB
•RMS Power Range : 600 Watts
•Peak Power Handling: 1800 Watts
•Impedance: 4 Ohm
•Frequency response: 23-400 Hz
•Diameter: 10 Inch
•Shallow Mount: No
•Number of Voice Coils: Dual
•Suggested Sealed Box Volume: .75 Cubic ft.
•Suggested Ported Box Volume: 1.2 Cubic ft.
•Mounting Depth: 6 Inches
First, turn off the bass boost on the iPod and put the subwoofer level to its default position on the head unit. Second, what kind of box is it in? What kind of amp is powering it?
When I do all of those things, there isn't much bass coming from the Sub.
I have it in an MTX figerglass stealth box. It's about .7 Cubic feet and it's being powered by a MB Quart ONX1.1000D @ 2 ohms.
Yeah, the SQ was definitely better with the W6... but it also hit harder. As far as the box goes... it gives it the recomended air space and it's the same box that I used for the W6. Who knows... maybe it is holding it back.
If I were to do a re-foam, any kits or places that you guys recomend?
Thanks
As far as the gain and the wiring, the shop assured me that all was wired and set correctly. I haven't touched the gains on the amp....However, I do see a problem with having to mess with all those settings in order to make it sound decent.
I'm seriouisly considering re-foaming my W6.. but I've heard that it's pretty tricky re-foaming the old W6V1's.
right, a 1 ohm amp at 2 ohms equals half power, which is most likely around 300w or so. maybe less with gain down. The type R's need a good bit more to get going, plus you're choking it with that enclosure.
Did the kit come with all the necessary hardware like the shims?
Also, how was the quality of the foam? I've heard that some companies use very cheap material that hinders the subs performance.
it seems to be a little more dense than the OEM surround, definately not cheap
and it doesnt come with shims but i just used balled up paper towels inbetween the spider and cone to hold it up and it was fairly easy to install
i was able to do 2 in under half an hour and let them sit for a day to dry
I took the W6 to a local shop to be repaired. I'm getting charged $20. The guy really seems to know what he's doing.... I guess we'll see how it turns out. I'll post pics next week.
joelx21
joelx21
So Cal
nudels
