After you cut the holes you'll mount the next sheet in place and use a flush trim bit in your router to make the pieces identical.Lol i could.....but I always seem to fry the coils when i give my subs more than rated power even if i use a multi meter and my oscope....i dont understand how people can give a 1500 rms sub 3000 watts daily and not fry the coils. How do you get the mounting holes on the baffle to line up on all the layers? I have a jasper jig but my cutting bit is only long enough for one sheet at a time. Ok I'll do two layers on the back, and i can switch the 2x4's and make them vertical. And yes i have no clue how much pressure they'll output ha. But im very eager to find out. Ive sat in a crx with two team rockford 15's and four memphis 2500's and it did 155 legal sealed
Alex used 2x4 and no sheets, IIRC he tore that one down in a week or two.I forgot who else used 2x4s for an entire she'll then placed 3/4 plywood on the inside and it came out pretty strong with no need for double baffles all around.
Sent from my Z970 using Tapatalk
Those 2x4 are the wrong way. They will flex and bend like that. I don't think u understand how much pressure three 18s will produce. You need to go into the build log section and look at 50 build logs and see what other people did because that 2x4 picture is going to failOk thank you hispls and tymoto.... I needed some guidance as far as what i need to do next...do you think if i used just 2x4's anr filled in the gaps with glue it would be just as strong as two layers of plywood? Because it's really hard to bend a 2x4 as opposed to a sheet of wood. Plastidip is easier to paint on than tinting the windows and its darker because its paint and not film...and no my amp is the 1 ohm version. And i know not to run it under 1 ohm, i made sure i did my research on that lol.... here's what i have done so far.....![]()
Either way should be fineWow! I really like that! Would you recommend that I do the 2x4's like that instead of vertical? Cause that's definitely not a problem.
Thin way meaning what? Like the picture the OP posted? Because that way is wrong and will flex bad. Pointless to do it that way.I would stack them the thin wayIt seems you don't have very much cf and if you take 3" + a layer of ply you will quickly see your 15cf wall turn into 10cf
It is much better to do it that way though
Laying down or standing up is still the same thickness so I don't think that's what he ment because it would be taking up the same space. The picture u posted I think is what he was talking about taking up less space because your using the 2" side and not the 4" side. Which is wrong lol.Lol he means thin as in how the studs are on a wall in your house.
