The 4th order thread
Yeah, when competing a huge ratio would be better because of rise for me (MECA is classified by cone area + fuse rating, could run a tiny fuse with that kind of rise) but I'm not too concerned with competing right now. I'm just tired of being limited to a trunk build and want to switch it up and possibly get louder. Most of my listening is music at full tilt for long periods of time while driving lol
2 Zv3 10s with a huge ratio on a ton of power would absolutely **** everyone else in the trunk class
its not as easy as I make it look lol. 4th orders take a good amount of work in both design and build to make them do work. I designed mine at least 20 times until I was happy
Yeah I get that as well. A musical box isn't going to perform as well as a burp box either lol
I'm just adding this to the list of things to do.... There's plenty of things in front of it... like ultracaps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and upgrading my rear suspension before it blows out
my "burp" box plays flat within 2db from 25-60hz lol if thats not flat then I dont know what is
more simple terms, typically, large rear= lots of low end, but lacks on the higher end from what I have seen, and the opposite applies for smaller rear ends. But I am a fan of my Fc being in the 45-48hz range for daily. I am not the best at explaining things, because I cant really put them into simple terms very well. hopefully everyone understands this. Also, I am no 4th order master, I dont have all of the answers, but I do know a good amount, mostly from testing, and educating myself. So please, if anyone else has some things that they would like to add, feel free to do so, I could always use some more information!
What is Vb?
Getting that spoiler under control lol.
so im starting to turn some numbers... Vb, where do i pull this number from. specs for my type r's is pretty conservative and also im assuming I would use sealed specs, right? and is the correct units to use for Vas liters?
Vb can vary drastically depending on your goals and the woofer. All of the t/s parameters basically determine box size as far as maximum goes. This is ported box size.
Most 10's it's about 1 cube.
Most 12's it's about 1.5-2.5 cubes.
Most 15's it's bout 3-5 cubes
Most 18's it's 5-8 cubes.
---------- Post added at 04:12 PM ---------- Previous post was at 04:12 PM ----------
For the type r's you can do 2-2.5 tuned all over the place depending on what you want.
for two of them I would suggest that, but with single spider suspension and such a low Fs already, that will get very sloppy on the low end. Too low of an Fc is terrible from my tests, lowest I would go is about 40. anything lower got really sloppy on almost anything. but to each his own. never tested with type r's
Those were ported specs.
oh, sorry //content.invisioncic.com/y282845/emoticons/blackeye.gif.66a1670f5aaf7f406e783a63e3387dc5.gif lol
---------- Post added at 06:01 PM ---------- Previous post was at 06:00 PM ----------
this thread was SUPPOSED to be for 4th orders... I got confused lol
RangerDangerV2
RangerDangerV2
st cloud MN
NO1B4ME
vegang
vegang
