Testing for best ground?
BassAddictJ
besides eyeballing it and finding something part of the frame such as a big metal support as opposed to something like the seatbelt box...... is there any way to test for the best possible ground? when it comes to moving ALOT of current, is it possible to test if one spotis better than another besides just hooking it up and useing that spot?
using a battery amperage tester.. if you have one available you can connect it to the ground cable then connect it to the amps battery + cable then try some serious current draws.. if you can pull 200+ amps through with out the unit shutting down i'd say you have a **** good ground
i that something i can get done at autozone? i knwo they have aload tester for batteries....but its probly not the same. where i can get access to one of these machines?
You can do the same thing with a dmm, just measure the DC voltage between the amp ground connection and the battery - terminal. If you get more that about .5V at full tilt on the amp the ground should be improved.
cool. i'll measure the bat terminal of the back bat and front bat at full tilt
make sense. well within the next few months im gonan be moving up to 8 runs of 1/0 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif so hopefully i can find a good spot for all them. I've heard the bottom of the fram is a good spot ussually. i can probly find a good spot near my spare tire well
I read on here a few weeks ago on how to do this with a DMM. It involved putting the positive side of the DMM on the positive on the battery I believe, then the negative on the DMM on the possible ground spot and just find where the the resistance is the lowest to put your ground.
BassAddictJ
BassAddictJ
FL
helotaxi
