testing box for leaks
Put a sub in it and play some intensive bass. move you hand around the box and see if you feel air.
ahh... yes, common sense..... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif ohh well it's too early for that.
when i used to be a mechanic and we needed to check for leaks in tires we would spray a soapy solution on the tire and where ever the leak was it would start to bubble
put a flashlight in the box turn off the lights. if you see light you have a leak
F_ing genious..... I probably would've never thought of that in a million years.
or
but instead of moving your hand around the box. Completly submerge the box in water and play it HAHAHA j/k.
If you have a leak.. it can be a very very very small hole where only air can pass and not light. So that might not be a full proof way to find a leak. Usually you'll hear the air coming out of the leaks. moving your hand around might be your best bet.
AcidicDreams
I don't need one of these
AcidicDreams
Auburn WA
helotaxi
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
