Testing amps
I just cut off the power cord to a lamp or something, strip the wires, and then hook it up to the power and ground on the amp.
Since power is voltageXamps, and wall sockets are 120v, you should get pretty good power out of some 12awg wire.
I did this with my Crunch amp and it lit up fine. But I always had issues with it afterwards...
Ok cool bro ya this is a mojo 4k so ima use 4 gauge .. But that's what I was thinkin too ... Two bad I don't have extension cord long enough then I could slam in the car
If you're running that much power, make sure to splice a fan into the wiring.
If you want to see how much power the amp is making, take some vice-grips, and solder the connections of a multi-meter on it, and then once the amp is powered up, clamp down the vice-grips onto the power wire and the ohm load should tell you how much power it is making.
Cool .. Pretty sure I got a big *** mister fan u can hook the hose up too for the patio .. I bet that sucker will work great .. Thanks man
Got a new amp commin today .. Quick question .. If I don't have my car going to test it I can just plug it into the wall right ??
Please make sure to take a video of you doing this so others can bask in your amazing light show and the release of the magic dragon!
Timmy13091
Team DC
Timmy13091
Chicago
marleyskater420
BP1Fanatic
BP1Fanatic
