so i was originally going to go with a blowthrough design, but have been reading other build logs and posts and came up with a new design. don't quite know if it is still a blowthrough design or not, but this is what i got.
the plan is to take out the rear window of the truck, seal it with the rubber boot replacement to this enclosure in the bed of the truck.
the view that you see is what will be facing the cab of the truck. the bottom wall under the space for the rear window should come up to the line above where it says 'KonFUSEed', the rest will be open.
i was thinking of getting a piece of plastic trim to go around the outside and still doing the bottom half in bedliner and painting the top half to match the truck. the hole in the middle will be a plexiglass window so i can still see behind me.
let me know what you think.
first pic is to show an overall view. second pic is to show how i revised for the amps to fit better.
but i still have a couple more questions about my setup.
first, how would you all run the wires from the battery in front to the one in back? i was thinking maybe just drilling through the bed and using some rubber grommets, any better ideas?
second is how would you run the wiring for the amps to hide it well? i was thinking of drilling holes and running the wires behind the whole enclosure, then attaching 1x2's around the edges and place another board over the back with the wires running in between the gap of the back two pieces, any better ideas?
