tell me what you think of my design
wafsman
ohio
so i was originally going to go with a blowthrough design, but have been reading other build logs and posts and came up with a new design. don't quite know if it is still a blowthrough design or not, but this is what i got.
the plan is to take out the rear window of the truck, seal it with the rubber boot replacement to this enclosure in the bed of the truck.
the view that you see is what will be facing the cab of the truck. the bottom wall under the space for the rear window should come up to the line above where it says 'KonFUSEed', the rest will be open.
i was thinking of getting a piece of plastic trim to go around the outside and still doing the bottom half in bedliner and painting the top half to match the truck. the hole in the middle will be a plexiglass window so i can still see behind me.
let me know what you think.
first pic is to show an overall view. second pic is to show how i revised for the amps to fit better.
but i still have a couple more questions about my setup.
first, how would you all run the wires from the battery in front to the one in back? i was thinking maybe just drilling through the bed and using some rubber grommets, any better ideas?
second is how would you run the wiring for the amps to hide it well? i was thinking of drilling holes and running the wires behind the whole enclosure, then attaching 1x2's around the edges and place another board over the back with the wires running in between the gap of the back two pieces, any better ideas?
kind of, yeah. as i said previously, the plan is to take out the rear window of the truck, seal it with the rubber boot replacement to this enclosure in the bed of the truck.
is this gonna be inside a camper top or something? you cant have this box and equipment just chillin in the bed of the truck...
no, it's basically going to be chillin in the bed of the truck. but it will be finished with panels in the bed portion, screwed to the bed, and sprayed with bedliner. the top half will be sealed to the truck with the rubber boot replacement, primed and painted to match the truck.
if you wanna do something like that, you're gonna need to find someone who can do fiberglass... mdf CANNOT get wet, and cant be just chillin in the bed of a truck exposed to rain... plus you dont want all your equipment exposed to the weather back there also
Its gunna look bulky and out of place standing up in the bed IMO. I like this design better.
. lay that box down and keep it out if sight
okay. since this is not getting through, i made you all some pic references.
the stock truck bed
the box chillin in the bed
with the accordian rubber boot replacement
box with panels
all finished up
i plan to spray the bottom panel with bedliner (like the rest of the bed will be sprayed with. the top panels will be sealed and sprayed with a epoxy enaml paint the same color is the truck.
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
554
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Without a photo this is the best I could come up with, note the "physical port length" is at 22.5" and if you measured down the portwall to get...
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
wafsman
wafsman
ohio
dr_peeb
