i need a ported box design for 3 12s type rs?
babaganoush123
this is going in a Chrysler 300. i need the box to be around 7-8 cubes ported at 33hz. i want the subs to be on top and have a slot port on the bottom.
trunk measurements.
45 inches in length
38 inch back width ( were the tire out lines are)
56 inch front width
23 inches height
19 inches trunk opening height
45 inches trunk opening width
thanks,
yes and no - you could build the sides that touch out of 1/2 inch and then bolted together you have 1", i would do a single board 3/4 on sub mounting side so you have 1 1/2 for mounting.
All this will do is possibly lead to vibrations and resonance. If you're going to put .5" against .5", you need to glue it together. Otherwise, those panels aren't really coupled together; they're just being held next to each other with fasteners.
so no on can help me with a design?
I could recommend you a few designers if you'd like. I used to do a lot of designing, but don't do car audio any more so you can trust that my opinion is non-biased. PM me if you want some help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
babaganoush123
babaganoush123
chicago
PV Audio
