TC 3000's X 3 15" DESIGN for JIMMY Needed ASAP
jdubbau
Car. Year, Make, Model: 2000 GMC JIMMY
2. Subs. Make, Model, Size, How many: TC SOUNDS TC3000 15" X3
3. Power. How much power per sub:1000-2500wrms Daily and comp
4. Goal. SPL or SQ: SPL with ability for good SQ
5. Sealed or ported: PORTED but maybe able to plug ports to have a sealed daily set up and ported to do good numbers.
6. Sub/port placement: SUBS BACK OR UP, PORT BACK
7. Max dimensions: 39" WIDE X 28" DEEP X 17.5" Tall
8. Desired NET vol and tuning(optional): AROUND 45hz
9. Finish: RHINO LINED
10. Zip code for shipping: DESIGN needed only with cutsheet and detailed layout if possible NEEDED ASAP!
11) Additional comments: THE SOONER THE BETTER GUYS
Other options I would like to incorporate but not must haves.
Double baffle: YES
Round over all port edges inside and out: YES 3/4" roundover bit to use
Round over all outside edges: YES 3/4" roundover bit to use
Kerfed port: Would like to go this route as its worked very well in the past.
Kerfed walls: WHY not if possible
Paint inside of port: YES GREY
Money in paypal waiting if someone can do the design very quickly, with a good solid design, and a good cut sheet and detailed layout.
Just let me know what you charge.
My Jimmy's Resonant frequency is right at 51hz and previous enclosures tuned to 42-43hz peaked out on the TL at around 47-48hz. Now not sure if it is true but I was told to peak out my numbers to tune a little higher at 46-48hz. NOW I do not like the outcome of the sound from this at all as it seems like every box I have tuned over 40hz does not sound the greatest besides the Nightshades I did a while back.
I would much rather prefer 30hz or so BUT this is not going to give me that great of numbers on the TL.
So this is why I am trying to find someone that can come up with a design that WILL be a ported enclosure tuned a little higher than I normally would for the TL and then plug the ports for a sealed enclosure to have a good bass response for my daily driving.
Anyone out there have GOOD experience doing this let me know as I need this design done TODAY.
Ok I understand they are very good sounding woofers as I have used them in the past and now have basically went full circle right back to them as they were the loudest best sounding woofers I have used.
This is just from my experience and my opinion from what I have used in the past few years.
I would love to just tune the box to 33hz or so BUT this is from what I am being told going to lower my TL score substancially. Which is why I am looking at tuning high and plugging ports for a SEALED enclosure for good bass response for daily listning. Is this just a bad idea or something? I have built lots of boxes here in the past 2 years and have been trying to come up with something besides a 2 box set up one for daily and one for comps, or removable ports to change out and this is what a few said they had great experiences doing.
jdubbau
jdubbau
evansville In
302yota
