taramps HD2500
Yes taramps are great. Clipping indicator usually aren't accurate so who cares. But yes, you got a solid amp.
370 total sounded good to me for a 2000+amp. And yes it was new
always check with the forum for better pricing man. I'd go with 4k and up with taramps or any other brazilians thats when their price to performance ratio shines. Under that you can get koreans with clipping indicator knob included for very similar price threshold. I'm cool with brazilian but not what they have 3k watts and under price wise.
Compared to most korean amps like the one I have are priced higher than these per watt. And mines a cheaper one. They seem to use less amperage. I don't need even 2500 wrms anyways, I'll be good with 1500-1700. I should've checked here first though
Someone was ridding stock is all it is.
We are one of 3 distributors for Taramp's and the HD series from 4000 on down is slowly being phased out with the DSP line which is tons better.
The DSP2500 is already available.
DSP advantage-
Wider operable power supply
Much flatter FR
higher signal amplitude for subwoofers
onboard voltmeter
thermal monitor indicators
Internal DSP
high SNR ADC
LOW THD compares to all HD amplifiers
Temperature controlled fans. Fans also shut off completely when temperature is adequate.
Adjustable Digital Phase Control
Adjustable centering bass boost FR with amplitude adjustment= DIGITAL
ANTI-Clipping module selection
All controls adjusted with visual indication.
Even Smaller, even lighter.
Newer modern heatsink for better cooling.
Any questions, just ask.
jersyn82
jersyn82
ohio
vegang
vegang
