Tantric Sub enclosure question
Theory
I am either going to go with a Tantric SHD 12 or 15.
General Shape of the vehicle.
My question is based on my picture of firing the sub into the cabin but using the trunk as the enclosure, the black line would be the wall the sub would be attached to. Since the sub needs around 5CUFT after the space the sub takes, 2 to 3 NS GP31 batteries, amp, and probably a small toolbox it should be around 5.5 to 6 CUFT.
In any way would this harm SQ or is this just a stupid idea?
If this is a good then I can go with the 15 if not I will have to go with the 12 since it needs around 2.5CUFT.
You mean use the trunk itself as an enclosure? If so, I wouldnt. Infinite baffle builds are hard and tedious. if you mean build the box in the trunk, go for it. That
Theory
Theory
Tampa, FL
thatguy12
