llamabob
I'm a noob putting together a budget system and need help making sure I have everything in order. The amps in question are a Cadence TXA-1502 and an Alpine MRP-M500.
Since it is a dual amp install I was looking at Knuconceptz KLMX Complete 8 Gauge Amp Installation Kit
for $15.99 or Complete 8 Gauge Amplifier Installation Kit
for $24.99. I will get 2 amp install kits in 8 gauge size, and connect them to a fused distri. block, connected to a 4AWG wire from battery to the block. Also using a distri. block for shared ground.
I'll try to keep this short and precise with my questions.
1. Which kit would you recommend, the KLMX or the second kit?
2. The amps are rated at 60a for the fuses, those kits include 50a fuse, will this be a problem?
3. I was going to use a 120a fuse next to the battery, is that the correct rating?
4. Is buying the 2 kits, then purchasing a seperate 4AWG power wire with a fuse/holder the best way to accomplish this, or is there a way with less headache/money?
5. Probably a dumb question but I plan to run power wire down left side of vehicle and RCA's on right, can both RCA's be ran together without any noise problems? Same with turn-on leads?
Thanks guys.
Thanks guys.
