System Tuning w/ midbass speakers
badstang123
I need some input on where to crossover my speakers since I have midbass speakers as well. I know typically you would crossover the highs at 80hz on the hpf and the sub around 80 on the lpf. How do the midbass speakers affect this though? Could I crossover the MB speakers at 250 hz on the lpf and bring the components up higher, like 150 hz hpf? I'm kind of lost so any input is appreciated.
Front speakers are MB Quart 5.25 P-series components (In kick panels)
Crossfire MB6 midbass speakers (In front doors)
Crossfire XT212 sub
My apologies, a mod should probably move this to the speaker or amp section. I wasn't thinking //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
What's the best way to go about limiting to those frequencies. The sub is easy, I can use the crossover and subsonic filter. But for my midbass and components the crossover's on the amps are only 50 - 250 hz.
If you can't do it with your HU, your only choice becomes some type of outboard crossover. The easiest and most efficient is a preamp level active unit. Going passive is also possible but not nearly as flexible and once you choose a freq there is no way to change it without swapping out components in the filter.
It kind of sucks because I have a Crossfire CFQ5.2 preamp equilizer that has a built in electronic crossover but it doesn't really do what I would need it to in this instance. What would be a good unit that would accoplish this without killing my pocket book? I might even be interested in a HU that would do this as well. Any eclipse units that would fit my needs? Thanks.
badstang123
badstang123
Los Angeles, CA
badstang123
