I have enough room to make the 15 work. Remember I'm selling the sub and the box to my friend, getting the same sub and getting totally new box..I just need input on what the specifications on the box should be so I can hit up a couple designers! And I wouldn't go as far as saying the box is "too" small, its just less than optimal. Its still 3.1 cubes after displacment and the sub still sounds good even on the lows. I'm sorry, but after hearing a 15 in a ****** box, I wouldn't go down to a 12 in a good box, especially since I can put the 15 in a good box. 15 or dieThat amp is "stable" at 1 ohm, that means it won't blow up, but I promise 1 ohm is very inefficient and loses SQ. You are probably far better off keeping it at 2 ohm especially if you haven't upgraded your electrical system.
Box is way too small, port is way too small. If anything you should sell that 15 and get into a good 12 which you may have enough space to do properly.
My current box is 3.34Cubes before displacment. And I have a BUNCH of trunk to work with. I can do 3.4cubes after displacment.2.5 to 3.75 ft^3
