System opinions
ddparker
I have a 2002 Buick Century as my everyday car and put in a budget system just to have some bass. I had two Hifonics HFX12D4s wired to 1 ohm running to a RE Audio DTS-1000.1 amp. I blew one of the 12s so since i had some old Pyle 10 subs lying around I decided to build a custom ported box for 3 of them. The Pyle's are much louder but the sound quality is horrible. I was thinking about getting 3 RE Audio SEX10D2 subs but I am open to other opinions if I can get better quality at or lower than the price of the RE subs(Sonic has them for 130.00 each). Would getting better subs also make my system louder or would I have to run more power?
For starters I would keep that Re audio amp for now, your subs needs to be changed C2 Audio is doing a pre sale on thier beffy 12" subs for $99 each free shipping from carstereogiant.com.
If you can afford to buy 2 of those subs your re amp should power them, but the good thing is if you decide to upgrade your amp later on, these subs can take more power. Here's the info Goodluck
Here's the link to buy
C2 Audio Threatcon-2
url=http://www.carstereogiant.com/product-p/threatcon-2.htm]C2 Audio Threatcon-2[/url]
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Can you stop recommending stuff thats not out yet before we see if its going to flop. Could be great design but fall apart out of the box
Have you seen a pre sale that is already out? This subs have better chance of not flopping and company has financial backup to get these lines going.
they might not but you dont know that. Its all off the shelf parts to save cost. Who knows what else they are going to go cheap on.
Did you suggest anything? with op's budget of $130 can you do any better than the pre sale of C2?
Thanks for the suggestion but my actual budget is around $300-400. I would like to stay under that but I want good quality subs which I know cost more.
I really want to go with 3 10's in a ported box so after searching around I can get 3 Sundown E10's for $100 each. I am assuming they would be better than the RE Audio but what do you guy's think?
Buy my 12 with the enclosure for $200 - Run your amp = 560 watts @ 2 ohm (rated) Should match up nicely to My DD 1012b D4 = Problem solved, Deeper, Louder, Better - Done Deal //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
472
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
913
16
943
ddparker
ddparker
Muncie, IN
naughtyca
    May 18, 2024
    May 18, 2024
