System not working
jharijan
I installed an MTX 1200 Watt amp and two 12" MTX subs a couple years ago and they bumped hard, but a few weeks ago the system started cutting in an out until now it does not work at all. I had the amp looked at and it is fine so I'm kind of confused, I'm not an expert with these things so not sure what to do. There is absolutely no sound that comes through the subs but the amp seems to still turn on when the car is on, any suggestions?
you can try metering the subwoofers make sure they aren't blown. or take a 9 volt batterie and test them see if they move. The easiest way to test if the input pf the amp is good is a Tone Generator if you plug it into the amp and there is sound try doing it from behind the radio threw your rcas and see if it still works. or test it with a meter.
jharijan
jharijan
Boynton Beach, FL
jharijan
