Running RCAs between Amps....
MikeyF
It is what it is
Hey, I just picked up a Kicker KQ30 equalizer and was going to hook it up, but have never really hooked one up. I was wondering how exactly to go about this, i've searched a bit, and basically got the idea that I want to go from the output on my Subwoofer amp, to the input of the EQ and I am confused from there on out. Like I said, I have a subwoofer amp, the EQ, and a interior amp. I was wondering how I would go about hooking it up. If anyone could help, it would be greatly appreciated, thanks.
if would actually be the other way around. the rcas from the head unit will go to the input of the eq, then the output of the eq will go to the input of the amp. this configuration goes for hooking an eq up to a subwoofer amp or any amp for that matter.
I appreciate it, thanks. So if I run it from my Headunit to EQ, then from EQ to sub amp, would I go from the output of my sub amp into the input of my Mids amp?
uhhhhhhhh no i dont think so..........
hu-eq-amp x however many amps you have. should have multiple RCA's on the back of your deck. if your deck only has ONE set of RCA's and your eq has like.... 3-inputs then you might have a problem. if im not mistaken.
that should be it.
Naaw, I have a Kicker KQ30, but it only has one output, if thats what you mean... So your saying run a pair of RCAS from each RCA port on the back of my HU, and run each to the amp, sub, and EQ?
i just looked at this eq.
i have no idea honestly.
i thought eq's had more outputs....or something.
MikeyF
It is what it is
MikeyF
Detwat, Michigan
MikeyF
