system impedance
No, there should be a dip in the system impedance right at the tuning freq. There should be two large peaks around the tuning freq. The lower freq. peak is the resonance of the port and the higher freq. peak is the resonance of the box. If your bassbox program does not show that than it is broken.
The program is broken or I am doing it incorrectly? There is a slight peak around tuning frequency of 43 hertz. Do you have bbp6 so I can send you the file to see if I did it correctly?
[screen shot] + image hosting = post a screenshot of the graph
As was said...there should be two peaks, one just below tuning and one just above tuning, with a valley at the actual tuning.
Flipx99
Violator of Terms
Flipx99
Building 100
squeak9798
