Sold System for Sale
csu87
Ive got 2 hifonics bxi2607ds for sale. 2600rms@ 1ohm and are .5ohm stable. clamped 4386watts @2.4 ohms @ 12.3 volts. 10/10 mechanical and 9.5/10 physical.
SOLD
Also have an Atomic APXX18 D1 for sale. was reconed alittle over a month ago.
$400+shipping
OBO or will take trades for big amps or some 18s
You do know that apxx is a apx 818 huge difference in subs..
i was told it is an apxx when i got it. it was reconed by team psi so i dont know if he could have upgraded the soft parts to apxx. from what i can tell, the only difference in the apx and apxx is the soft parts. it has a foam surround like the apxx, unlike the rubber that the apx has, and can still take over 4k watts
lol are you serious... 102 volts... to clamp test an amp you take amperage draw of the amp and multiply that by your resting voltage. so your vehicle is making 102 volts.. unlike most vehicles running 12-14 volts.... YOU R AN IDIOT. and thanks for the email saying **** my **** and claiming numbers. I guess you missed the part about how to test the output of amps..... de de deee! If you wanted to prove me wrong you should have tested the amp correctly. Its amperage draw x power input. so your voltage the vehicle dropped to by the amperage drawn say like 200 amps. 300 amps etc. I know the ddz1 drew around 300 amps of current on a few bench tests done. so lets use that as a comparison. 300 amps of current draw x lets say the 12.5 volts you saw on one of your other videos 300 x 12.5 is 3750. are you claiming your amps were better then A DD z1? REALLY? I do have better things to do. LIKE TELLING THE TRUTH. I don't claim to have the biggest baddest setup. however when I claim numbers or specs they usually are LEGIT. People can read right thru your bs.
maybe you cant read but the numbers are for both amps strapped. i never said 1 will do that kind of power but 2 definately will. second, maybe you dont know much about electricity, so i will help you out. volts across a wire x amps across a wire will equal watts across a wire. i did it the way sundown tested his amps, just he used an rms meter and i had to use a clamp and voltage meter to come up with the watts output. i dont see him clamping the power cables, i see him clamping the speaker wires, but i guess he doesnt know how to do it either, right? now if i wanted to see how much power was going into the amps, i would clamp the power wire and that would give me how many watts go into the amp, however, amps arent 100% efficient so how would that help me? lets say they do draw around 200 amps each like you said. 200amps x 12.5 volts = 2500watts per amp so that would be a total of 5000 for both by your logic which i know is unreasonable.
amps gone
sub still here
Ok so I found out from wu today that the 818 is the apx motor. I also found out from the guy I got it from that it was reconed using apxx parts. So it's an apx/apxx hybrid. It still takes 4k+ daily without breaking a sweat so I do 350+shipping.
yes thats how it is measured and those amps wont pull that current lol. not rms. so I lol @ u my friend. Its common knowledge on how to measure output of an amp. its resting voltage x amperage current draw.= output. the more you talk the dumber you come off man. Look up what it is your talking about before you start talking junk!
so resting voltage x current draw= output. but what about efficiency? where does that come into play? it is you who should do some research
ttt for the sub
csu87
csu87
C Springs, CO
SicAudio
