System doesnt sound as good as it should
something aint right ... im leaning towards box/ground/amp... i got two type rs in a generic sealed pre fab... on a 400w fosgate at 2ohms and i cant complain lol.... i was actually surprised... lol
in a trunk the bass sounds terrible when the subs face the front of the car without actually walling them off or porting through the deck or seat.
turn the box around like mentioned .
make sure your ground is not grounded to thin metal.
make sure your ground is sanded down to bare metal period.
and for sakes get rid of the cap. its been proven to hurt systems.
i had a car that ran 1k wats rms no light dim. bought a diff car and the voltage drops 0.2 volts and i got headlight dimming. some cars headlights dim on a low voltage drop like that period. dont always assume you need a bat or cap just because your headlights are dimming.
doesnt matter its all part of a proper install which a lot of things you already have done wrong, improper ground will cause future problems. along with current voltage issues.
OK Sanded Ground and now have the box firing at the back of the car. no difference. Maybe box?
it restricts flow of current to your amp. You are getting less dims but a lot less power at the amp At heavy voltage drops, you are starving the amp of voltage with the cap.
Not sure where you're getting your information but this is simply not true.
I don't need you to educate me on capacitors bud. I'm not saying audio capacitors fix any of the myriad of problems they're marketed for. I'm saying his statement is not true. Electrically/Physically that is not how capacitors work.
If you would watch that test it confirms what you say is not true. So it looks like you do need to be educated on how they work.
If you can provide any technical data then I would more than happy to entertain this discussion. Posting a link to a half-assed youtube experiment is not technical data (There's a reason they disabled comments on that video). Ideal* Capacitors do not consume energy they only store it, so the idea that they could constantly restrict current flow is absurd.
His statement about the 'right' and 'wrong' way to wire a cap leads me to believe he doesn't have any idea what he's talking about either. A capacitor is wired in parallel with battery/amp/etc meaning where it's connected has very little effect on what it's meant to do which is be a quick supply of current during heavy draw.
Again, I'm not making an argument for the use of capacitors but I will make an argument against false information about their effects.
*I realize there is no such thing as an ideal capacitor and they will all have some impedance and leakage however this amount is negligible when referring to the scale in question.
Any links to conclusive technical data?If i'm wrong I would like to know what it really does. Rather than getting info based off a EMF video.
most likely your amp and head unit settings are out of whack or your box tuning inside your car does not work. EAch system sounds different in different cars.
van06TL
van06TL
United States
basswiigee
