Southern_Exposu
First off, let me say this is an experiment. I will be eventually putting some Sundown or Dayton 10s in this vehicle. But for now, I want to try out some super cheap 10s that seem to have a decent following with pretty good reviews. So if these melt or die, I'm cool with that. However, I do want to attempt to to have them be successful. These will be in a sealed enclsure with either .75 or 1.0 cu ft of volume. I have several amps amps that can do anywhere from 300W @ 4ohms to 1100W at 1ohm and a pair of Optidrive 1400Ds for the Planet 10s if that's the way I go... assuming they will handle 750W RMS
Below are the subs in the running. If Anyone has any other suggestions below $45 each, that'd be great too.
#1 - GRS 10SW-4 -- $20
https://www.parts-express.com/grs-10sw-4-10-poly-cone-subwoofer-4-ohm--292-482
#2 - Jensen DUBw10 -- $30
https://www.crutchfield.com/p_110DUBW10/Jensen-DUBw10.html?tp=68872
#3 - Skar IX-10 -- $45
https://www.skaraudio.com/collections/ix-series/products/ix-10?variant=17677557313
#4- Planet Audio AC10
https://www.ebay.com/itm/Planet-Audio-AC10D-1500-Watt-10-Inch-Dual-4-Ohm-Voice-Coil-Car-Subwoofer-/323294097517?_trksid=p2385738.m4383.l4275.c10
