Sundown Audio Nightshade 18'' -- AQ2200 >> Truck Build
Bobby322
TX
- Nightshade 18'' with new aluminum pole w/ 4 spiders (2 soft, 2 hard)
- AQ2200
~4.5^3 @ 32hz (after displacements)
The desigin comes out to 5.5^3. With sub, port, and bracing I think it will be around 4.5.
The port may have to be resined up for extra strength since its weaker than aeros. How should I brace it? Ive never have done tube ports before, so I don't know how I should brace it and attach it to the box, etc. Any help on that would be very useful.
The tube is 8'' diameter and I'm cutting it to 24'' for 32Hz tuning. I was told this will take up about .5 cubes? Its 48'' long so I have plenty to work with.
I don't know how to do the math, but how much depth for the sub will I have with that box design? Since I have the aluminum pole I dont need to have space for the pole to vent (thanks jbizzle)
Looking forward to seeing this done //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Got an estimated time to completion? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Probally will start as soon as tomorrow. Should be done sometime next week. I've got thurday-sunday off
Lol will make the box 48'' instead of 47.5 since the sheets are 48'' long...1 less cut
Hahah if it still fits then go for it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Subscribed, wanna see how it ends up //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Thanks..
Just did the math and the sub should fit fine.
I was hoping I could use threaded rods for bracing but I dont think that would work well on the angle.
Should be good, in for this.
Thats going to be quite loud in that single cab, //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Some of the NVX stuff seems alright, but the amps, especially the higher end ones, they seem suspect and sometimes show stats that straight up say...
13
5K
Bobby322
Bobby322
TX
HSWaypeType
    May 18, 2024
    May 18, 2024
