suggest clean system for old timer
Woah, and I thought being out of car audio from 2001 to 2007 was bad and I am 36 too.
I know, stopped when I got about a year out of college. Fosgate "punch" were the hot items, as were Hi Fionics (sp??) amps and the PPI art series amps. Now I am more into home theater stuff and all of a sudden I realized how much time is spent in the car and decided to upgrade the stock system. Also, driving around for 2.5 years listening to Sirius through an FM transmitter and not being able to use my Ipod and new Iphone kind of pushed me back into car audio.
--JK
--JK
I stopped when I was married in 2001, then my wife became ill in 2005 and died in 2007:(
I became a little frustrated with my 2006 Mustang GT's setup and gave up for a month, but I am about to jump back in and finish it.
Do yourself a favor and go listen to some Image Dynamics subs/speakers.
As for HU I would look at Pioneer. It is VERY user friendly generally.
Also, if you are worried about waranty from buying online woofersetc.com is authorized for ID at least, and should be quite a bit cheaper than local retailers.
I say........ this would be a fun little project, I think some of you missunderstood, he said he wants quality as well. I would go with the new Mag v4 12" sub. Its ony 5.5" total deep and if im not mistaken you can mount it at 4.75" which basicly means you only need a 1 cubic foot sealed enclosure (Major space saver). They are very loud, very acurate and have a very clean sound. They handle 1000 watts so you could run a Sundown Audio SAE-1000D which is a good quality/reliable amp. If anything look at all your options before you purchase. Here is a link for you...........http://www.stereointegrity.com/order.php
Woofersetc.com has good deals on old ppi pc series amps. Those would be the amps I strongly recomend. Most company's don't make amps like these anymore and if they even come close they charge a arm and a leg for em. Don't let the low watt rms scare you away from them, they're are hella underrated and are just outstanding sounding amps.
As far as component speaks, get the best cdt audio's you can afford.(hopefully the hd's) I think woofersetc is having a sale on them too and they sound extremely good with rock.
For a sub, jl audio makes good subs for rock. Also image dynamics, whatever sub you get though, id put the most amount of power that it says the sub can take. With rock it helps to have the headroom and you don't have to worry as much about blowing it.
For a head unit, there's a lot out there. Pioneers are nice, so are alpines. If your gonna be using your ipod with it you should look into how they work together. Some decks control the ipod better than others. Just make sure if it has a cd player that it has a 24 bit digital to analog converter.
There's a lot more involved with the install then the equiptment when it comes to making a system sound good for rock.( a lot easier with rap) When it comes time to install it, take your time and don't cut corners. Make sure to use the correct size wire for both power, ground, and speaker wire.( use at least 14 gauge for speaker wire and preferably 12) don't use cheap rca's. Makes a big difference. Run your rca's and your power wires on opposite sides of the car. One of the biggest things you could do to make it sound good is use dynamat on the doors to really seal them up and dampen them.( also makes a big difference) hope this helps...
rickelrod
rickelrod
b,ville, Va
BassMechanix
