But why would it work perfectly fine for a week then just cut out all the sudden randomlyHe's out to just ruffle feathers. A real 1k amp like a jl slash 1000/1 or sundown 1k or sound qubed 1200... Your boss amps prly does like 300watts real power.
Its basically bottom of the barrel in terms of performance and reliability. Anytime you touch boss, crunch, power acoustik, autotek, planet audio, pyle, pyramid, cheaper lanzar, you are just wasting money on a doorstop for future reference.So would I need to get a larger amp then? Why would it work for the first week though then all the sudden cut out?
Could you recommend a good amp then to switch too?Its basically bottom of the barrel in terms of performance and reliability. Anytime you touch boss, crunch, power acoustik, autotek, planet audio, pyle, pyramid, cheaper lanzar, you are just wasting money on a doorstop for future reference.
your boss 1100 watts is literally 100 actual real world watts on its best day. The quality control for these companies are non existent. They are just out there preying on noobs with exaggerated power claims.
depends on budget and what subs you are using and what kind of box you are using.Could you recommend a good amp then to switch too?
Robot Checkdepends on budget and what subs you are using and what kind of box you are using.
most likely the subs arent deadRobot CheckThat is the sub + box combo im hoping that them playing quiety does not mean they are permantly dead
nothing more than 200 dollars
No, just plug and play. the 650.1 is closer to 8 gauge than 4I Have 8 gauge wire ran for the power. Would I have to rerun all the wires?
What about the 1000?No, just plug and play. the 650.1 is closer to 8 gauge than 4
single soundqubed hds 312 in a custom ported box. Around 200 dollars total after wood costs..What about the 1000?I plan on testing the subs with multimeter tommorrow if there still good then im gonna buy 650. If not I will buy 1000 with better subs in the summer time. Again out of curiosty do you reccomend any setup to go with 1000 watt? I have 2011 Mitsubshi lancer
reduced power output and excess heat is if you overdrive the amp.Are there any safety precautions because im going to use 8? excess heat?
