Subwoofer Box
You need the cut out diameter as well and yes you need to include port displacement and bracing to get an accurate Net volume
Sent from my Z812 using Tapatalk
When building a subwoofer box what are thethings you look for on the subwoofer spec sheet? Is it just woofer displacement? Also do you need to include the bracing and port displacement? Is there anything else I'm missing?
Use Torres box calculator to help you factor in the displacements and get a net volume. Yes you'll need to add the bracing and sub. It will calculate the port disp.
AcuraTL
AcuraTL
Burnaby
CSCStang
