hdc3 12 help
The box is 35Wx14.5Hx17.75D. Port is 3.25Wx13H and port wall is 33. It's 3/4 mdf and has a double baffle. Has 45's for bracing. The way I figured it was around 32-33hz. 14 nissan sentra, trunk toward the trunk opening
box specs check out okay, so whats missing in your music? Overall output? not hitting the lows? upper bass punch missing or not getting that choke feel? Sloppy? Or just not hitting a wide range of notes?
You are around 2.7 cubes after displacement. Try putting some 2x4s in the box to take up more space(put a lot in). This should raise the tuning up and create less of a peak at tuning frequency.
Let's see some pictures of the box installed.
Why did you chose to tune 32hz when Soundqubed site recommends tuning higher?
Think of the box being a regular box w no double baffle, screw and glue one to the front and that's what I got. I messed up on build. I mean it's solid. Btw my camera isn't working today
[quote name='jersyn82']I would but I've already built a box...I'm trying to make this one work if it's close[/QUOTE]
They have box calculator apps for phone and pc. Try some them. I'm sure @CSCStang can help you out with raising your tuning
Sent from my Z812 using Tapatalk
jersyn82
jersyn82
ohio
jersyn82
