subwoofer box design for platform 1 PSI 18
maddew
hey guys i want to get a platform 1 psi 18 but im not sure how to build the box...the dimensions of my trunk are:
Width: 35in
Depth: 30in
Height: 15in
that comes out to around 9ft3
could someone design me a box tuned to 28hz please?
Re = 3.0 ohms
Fs = 26.3 Hz
Qes = 0.85
Qms = 9.6
Qts = 0.782
Sd = 1230cm^2
Vas = 290.1 L
BL = 15.25
Mms = 277.1 g
Sensitivity = 89.8 dB @1W/1m
Sensitivity = 90.4 dB @2.83Vrms/1m
Xmax = 56mm total
Usable excursion = 3.5″ total
recommended enclosure size for ported is 5.5-10ft3
i listen to hip-hop music
the subs rms is 1000 watts, dual 2 ohm
im running a hifonics brutus brx1100.1D
ported box either slot or round doesnt matter
let me know if im missing something
please and thank you :)
im not sure you have enough room for that but Ill say that it wll get low down into the 20s no sweat.. are those measurements external or internal? if they are external you have a hair under 7.5 cubes.. thats on the small side for this driver..
im fine with low 20's and external
you honestly don't have enough room for the woofer to really perform as intended. what car do you have? is there anyway you can trade for a 15? i don't see it doing well in 6 cubes..
yea i could i trade for a 15, the 18 was just an idea, i knew it was going to be iffy but i can do a 15 and i have a 2015 chrysler 200
make sure you have enough room for hte woofer to pressurize the cabin. in my car it killing output because i have about as much area for pressure to transfer from the trunk to the cabin so once i reach a certain output level compression occurs and limits output..
what if i seal off the cabin with the box? will i still have that problem?
maddew
maddew
Florida
Papermaker85
