Subs with thin tall surround and high xmax
I don't know about other series of DD but 9500 has over 1" one way excursion and must be linear.You can check my 9515 pushed to limits here
http://www.realmofexcursion.com/videos/Digital%20Designs/9515.2.wmv
The 9500 series has about 14mm of xmax if I recall correctly. And again, you're confusing xmax with the throw of the sub. DDs use an underhung motor design which almost always yields a smaller voice coil length and lower xmax. This does NOT mean that it's total throw is limited nor does it mean it sucks like people seem to thing. Contact DD and ask them if you don't believe me.
The voice coil length of dual 2ohms is 42 mm and the gap height 32mm.This is not underhung.I have done the recone myself and have the old coil.
The 14mm xmax you are refering to is based probably in a dumax test in a 9515 B series and is 12.9mm exactly.I don't know about the B series voice coil and gap height.
If you see the sub moving almost 3 inches back and forth by its own motor power without audible distortion you call this just throw?
luv2bass
luv2bass
LA
ngsm13
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
