Subs to amp match question
nogales
Hello, i'm trying to figure out what type of amps I would need to power two Volfenhag ZX4712DVX subs, these have dual 4 ohm voice coils, the power handling is 500W continous (I guess thats 250W per coil)
I want to run them at 4ohms stereo, i know i would need two amps that can handle 250W per channel @ 4ohms, I saw a Crunch V-2600 that has 250W X 2 at 4ohms, but i dont know if thats the maximum output, or if its continous and in any case if its enough.
Thanks
hahhahaa, you a prick db, hahahha
another idea is to get the Hifonics Z1000D. Ask limitkid7, he's pretty happy with it.
connect each sub in parallel, and then parallel between subs.
if this pic didn't work, go to http://www.rockfordfosgate.com/2002home/
nogales
nogales
Nogales
ftgu
michigan born
    May 14, 2026
michigan born
    May 14, 2026
