georgems65
it is going to be 3 separate boxes. here are the specs of the subs. i kinda need help with the porting of them i dont know how to tune ports o anything about ports. i know how to build and thats it. help.
HERE ARE THE SUBS
- Double Magnet Construction
- Double Spider
- Frequency Response: 25Hz - 800Hz
- Impedance: 4 ohms
- Magnet Weight: 63.4 oz
- One-Piece Cone Design: with Red Metallic Center Emblem
- Pearl Mica Injection-Molded Polypropylene Cone: 12" Typhoon-Type
- Power Handling: 800 Watts
- Sensitivity: 93dB
- Speaker Connectors: Gold-Plated, 2-Way SB-Type
- Urethane Surround: High-Roll, with Perpindicular Inner Wall
- Vented Voice Coil: 2-Layer
THIELE-SMALL PARAMETERS
- DC Resistance (Re)
- Electrical Q Factor (Qes)
- Force Factor (Bl)
- Mechanical Q Factor (Qms)
- Moving Mass (Mms)
- Peak Excursion (Xmax)
- Resonant Frequency (Fs)
- Total Q Factor (Qts)
- Voice Coil Diameter (d)
- Volume Acoustic Compliance (Vas)
HERE IS THE AMP
MonoBlock, Class D IQ Series Amplifier
Max Power, 2 OHM 2200W x 1
RMS Power, 4 OHM 1200W x 1
Max Power, 1 OHM 3000W x 1
Class D Circuitry
1 ohm stable
Signal-to-Noise Ratio > 100dB
THD 0.05%
Remote Subwoofer Level Control
Variable high & Low Pass Crossovers
0 - +18 DB Bass Boost
0 / 180 ° Selectable Phase Shift Control
RCA Line Inputs
Speaker Level Inputs
RCA Line outputs
Gain Control
Power and Protection LEDs
Input Sensitivity Selector
Ultra Compact-Size: Only 2" High
Dimensions : 6 1/2"W x 2"H x 16"D
please give me some advice remember 4 of these
HERE ARE THE SUBS
- Double Spider
- Impedance: 4 ohms
- Sensitivity: 93dB
- Force Factor (Bl)
- Moving Mass (Mms)
HERE IS THE AMP
Class D Circuitry
1 ohm stable
THD 0.05%
RCA Line Inputs
RCA Line outputs
Gain Control
